AutosystemXL Error
Greetings,
Has anyone ever encountered an error on their Autosystem XL that reads as follows:
"No DTF3 Flow Module at Connection 5.'
Thank you for your assistance.
Cyprian
DTF is the detector flow. It is not recognizing the PPC module (i believe position 5 may be for the air?) on the PPC board. Make sure the module cable connector is seated well on the PPC board. You could have a bad PPC module, PPC board or even a Main board.
It was the main board along with the PPC module. Thanks for your comment!
Hi
I have the same issue on my Perkin elmer GC 'Warning CAR 1 pressure less than 50 psi'
Please advice.
Hi
Please advice.
open your cylinder valve and set it to 100 PSI.
then, check for leaks, and you'll fix it.
In total there are 30 users online :: 1 registered, 0 hidden and 29 guests (based on users active over the past 5 minutes)
Users browsing this forum: Google [Bot] and 29 guests
