CG 6890N PEAKS
Hi
every timer i performance a blank run, a peak apears betwin 4 and 5 minuts
My device is a agilent 6890n, whit a TCD and PPI
How i can do to resolve this problem?
Hi
What do you mean by blank run? No injection or solvent injection ?
Column? Valves? Carrier? The more you tell the more helpful people can be.
Best regards,
AICMM
thanks
Colunns: Packed columns 10 ft mesh 45/60 stainless steel
10 port valco valve whit Gas Sampling with Backflush to Detector configuration
PPI inlet
Carrier gas Hellium
The chroma was off by more tan year
The TCD is a new element
