Petroleum (Vaseline) peptide ointment extraction
I have a problem with extraction of melittin - a 26 amino acid peptide from petroleum ointment.
My method:
1.~0.250 g of melittin ointment is dissolved in 2 ml of n-hexane
2. LLE is conducted - 2 ml of 25%ACN is added and solvents are stirred for 30 minutes
3. The 25%ACN layer is centrifuged
4. 100ul HPLC injection is made.
Problem: Recovery is only 80% (i need 95-105%)
I tried various concentrations of ACN and 25% ACN was, unfortunately, most effective.
I tried also Isopropanol, and methanol and they both were weaker than ACN.
I tried adding 2x 1ml of 25% ACN for 15 minutes and the recovery was the same
Any suggestions?
Cheers,
Dorian
Hi Dorian
How are you calculating recovery ?
Thanks for response,
I prepare spike :
1.~0.250 g of blank petroleum is dissolved in 2 ml of n-hexane
2. 2ml of peptide solution of expected* concentration in 25% ACN is added, and solvents are stirred for 30 minutes
Recovery is mean area of peak from ointment/mean area of peak from spike *100%
* The ointment is concentration is 0,5mg/1g so
in 250 mg of ointment there is 0,125 mg of melittin so
concentration of peptide solution was 62,5ug/ml
Dorian
You might try tweaking the pH of the extraction solvent. Look at the sequence and see whether you have a significant number of acidic or basic residues and adjust pH to ionize a majority of them. That might shift the equilibrium enough for your purposes.
Hi Dorian
How do you know that ?
What result do you get if you spike the vaseline (not the vaseline solution) with mellitin ?
sorry for the delay in response. Thank you both tom jupille and Peter Apps for your help. After i applied your advices to my extraction, the recovery became ~100%. :)
I know that concentration is 0,5mg/1g, because i made this ointment :)
Dorian
In total there are 0 users online :: 0 registered, 0 hidden and 0 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 0 guests
