Waters HPLC Compression test failure
HI All
I did the compression test on my Alliance system and it failed . It is giving an error message ‘INJ pressure increase on comp check’
Can anyone advise me on what the problem maybe
thanks
Paddy
You should check with Waters. I don't have access to that system, but from context, I would suspect you either have leaking seals or check valves.
Users browsing this forum: Semrush [Bot] and 14 guests
