Thermo trace ... No heating of,the ion source
Dear all,
I cleaned for the first time my ion source by myself and I had to replace the heating board by a new one.
Unfortunately when I put everything back in place, it still does not heat... What could be the problem? I double checked the connection and everything is ok. Also the hardware test shows that everything is ok but the heating...
Is there a way to check if the heating is working without having to,put everything under vacuum again?
Any idea what the problem could be ?
Thanks a lot,
Kevin
Now that I think: if the fuse is out of work, would it show it in the tune tests? Or would I have to check it myself?
In total there are 35 users online :: 1 registered, 0 hidden and 34 guests (based on users active over the past 5 minutes)
Users browsing this forum: Google [Bot] and 34 guests
