gas % to ppm conversion
Greeting guys,
I need help to convert gas % to ppm, here are the gases:
H2: 40%
CO2: 35%
N2: 20%
O2: 5%
Thanks. I
I always think about gas-phase ppm as "µmoles analyte/mole of ideal gas". So, for 5% O2:
0.05 mole O2/mole of ideal gas x 10^6 µmole O2/mole O2 = 50,000 ppm O2
etc. It turns out that the volume ratio is the same as the molar ratio (transformation using the ideal gas law, at a fixed pressure and temperature of course). I just like to think about concentrations in terms of some type of mass relationship.
Are you asking about converting to weight ppm? As in trying to do a mass balance?
Best regards,
AICMM
Simple. There are one million "parts per million" in any mixture. When using percentage, 100.0000% is useful to consider. Thus, 0.0005% is 5 ppm. It follows that 1% is 10,000 ppm, and 6.5% is 65,000 ppm. And so forth. See the pattern?
Merry Christmas!
