Bruker 450-GC - Rear EFC Flow Alarm
Looking for some help with a Bruker 450-GC.
I keep getting the fault "Rear EFC - Pressure ready time out" the flow is fluctuating and the GC remains in Not Ready mode - I can clear the fault by de-selecting and re-selecting the Enable box in the Rear EFC tab.
Is this a genuine flow/pressure fault or is it a gremlin in the software?
The flow also takes a bit of a wobble about 1.5 mins into a run, this clears and appears not to upset the results.
Any ideas?
Many thanks
Caleb
Welcome to the forum.
First step is a leak check, with a leak seeker. Also, measure the actual flows from the split and septum purge, and make sure that the septum purge flow and column dimensions are set correctly.
Users browsing this forum: Bing [Bot] and 24 guests
