GPC
Discussions about gel permeation chromatography / gel filtration chromatography / size exclusion chromatography
GPC
For PPG 4000 analysis what calibration curve do you used?Thank's
You could use PEG. This standard is available in a range from 106 - 40k Da. Use the same eluent as with your samples. As always, it is a relative calibration.
Gilbert Staepels
Ideas mentioned in this note represent my own and not necesseraly those of the company I work for.
Thank's a lot.
GPC
What calibration curve do you use for glycerol ethoxylate propoxylate with molecular weight 3500 -4000 Da?
If the compound is soluble in Tetrahydrofuran, then I use the Polystyrene curve. If the compound is aqueous soluble, then I use the PEG curve.
