Sep Pak vitamin D
I I am looking fo a Sep Pak cleanup for concentrating Vitamin D2 and D3 prior to HPLC analysis. Has anyone done this . The sample matrix is an extract after saponification of feed samples.into hexane
A Sep-Pak concentration of these very non-polar compounds from hexane might be tricky. One possibility might be with an alumina Sep-Pak. How much hexane do you have? I personally would rather consider an evaporation to dryness (hexane evaporates easily).
There is this 5-cm thick book on Sep-Pak applications. Do you have access to it? I do not have it at home, but I can check at work on Monday.
The hexane can be rotovaped easily . Thanks for any help. What is the name of the book . I may be able to find it or order it.
- Kazimierz
Hexane extracts after evaporation contain yellow residual from blood
serum. Vitamin D3/D2 and metabolites are reextracted into acetonitril
as injection solvent.
I have not found something specific for your application. However, there is a publication in J. Liqu. Chromatogr. 4(1) (1981) 155-164 on the analysis of the D vitamins from vtamin preparations such as resins, oils, concetrates and gelatin-protected beadlets.
In total there are 12 users online :: 3 registered, 0 hidden and 9 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], Google [Bot], Semrush [Bot] and 9 guests
