Benzalkonium Chloride Method
This is a pretty simple post, i hope. I'm looking for a Benzalkoium lc uv method that uses something other than a cyano or SCX column. Any help would be great.
Look for Chrompack application note #99, uses ion paring on a C18 column.
We have a method for similar compound cetylpyridinium chloride with perfect symmetry and retention control. Check the following link, it also shows retention on C18 column. Our column is a mixed mode column with combination of reverse phase and ion-exchange groups.
http://www.sielc.com/compound_113.html
Compounds like benzalkonium tends to tail a lt due to residual silanol interaction, evan end-capped columns show tailing (in our comparisson it was leading brand C18 end capped column).
Contact us if you have questions.
regards,
Vlad
regards,
Vlad
Hamilton Application Note #280. Uses a PRP-1 reversed phase column in straight RP mode.
Best regards,
Robert Haefele
rhaefele@hamiltoncompany.com
Best regards,
Robert Haefele
Dear Robert,
Can you provide a link to the method. I tried to find it on the website but did not see it.
you can email it to vlad.orlovsky@sielc.com
I want to compare it to our method (peak shape for quaternary amines)
regards,
Vlad
regards,
Vlad
http://www.hamiltoncomp.com/cgi-shl/pro ... applist280
Peak shape is actually not that great. Some improvement might be possible by running at elevated T and by using a 3 or 5um PRP-1 column. The application note is pretty old (>15yrs?) which explains the 10um particle size.
best regards,
Robert Haefele
best regards,
Robert Haefele
You could also try the Acclaim Surfactant column. Featured on the homepage at www.dionex.com
Mark Tracy
Senior Chemist
Dionex Corp.
Senior Chemist
Dionex Corp.
I have used amino phase for LC-MS of these compounds.
Users browsing this forum: Google [Bot], Semrush [Bot] and 5 guests
