Automated method development
Does anyone have experience with the Waters AMDS. If so has the experience been good?
Any advice would be appreciated.
Rob
Rob,
I haven't used it myself, but I believe our chemical development dpartment have used it, although I'm not sure how successful it has been.!
Personally I have severe reservations about its use (although the good intentions are there of course). Some of these have been discussed before on this actual board - its a matter of searching for them!
As I see it though, some reservations:
1) How does the AMDS auto integrate? Peaks that are baseline aberations should not be integrated. Integration by the human eye is far more accurate, especially for impurity runs!
2) Will it account for peak shape dificulties (on on-going problem for many chromatographers out there).
3) Does it incorporate temperature / tG time programming as per a manual DryLab approach.
4) How have the chromatographic community taken to it... can't say I've seen many papers on it detailing its attributes such as precision, ease of use etc.
I can comment on some of Rob's points (bear in mind that I'm not unbiased, since I was involved with the development of the system :wink: ).
The system was never intended to be used directly with impurity samples; it was designed for major-component type assays (potency, content uniformity, dissolution, etc.). The only way to use AMDS to effectively develop impurity methods is to work with spiked samples. This is no secret, one of the first few screens when you run the "Chromatography Manager" (the program that controls the method development process) says that it is not designed work with peaks of < 1% of the total area (in fact, it will ignore those small peaks).
The short answer is "no". AMDS is basically a selectivity-manipulation program. If you have tailing problems on a pilot run (usually a full-range gradient), those should be dealt with first, for the very good reason that the things we do to fix peak shape problems typically impact selectivity as well.
That's another easy answer" "yes". In fact the AMDS system uses DryLab. What it does, essentially, is to start with a set of user requirements and some basic information about sample chemistry. Based on that, it assembles a sequence of up to six proposed tG/T models (using different columns, organic solvents, and/or pH values) ordered by expected probability of success (as defined by the developers). It then runs the calibrations for each tG/T model in turn and evaluates the resolution map. If no conditions are found that meet the requirements, the program goes on to the next model. If suitable conditions are found, the program runs those conditions to confirm that they do, in fact work, and then exits.
Beyond making the general point that AMDS really doesn't address accuracy and precision (the focus is on selectivity and separation) I can't really comment on that since I haven't been officially involved in two years. I'd be really surprised to see papers on it, though, because it doesn't break any new chromatographic ground. What is does is automate a well-known, well-documented strategy.
To the extent that I've gotten negative feedback about it, that comes from people who are pushing the system to do things it wasn't designed for (e.g., impurity methods without spiking). The assumption seems to be that it should be able to do the hard separations; the reality is that it was designed to do the easy ones unattended so that the chromatographer can focus attention and time on the challenging ones.
Rob,
1) you can use AMDS in anther way: set the limits such critical that it won't find a suitable prediction (eg Resolution of 5 in less than 2 min).
AMDS will run through all the models, and the day after, you can integrate manually, allow AMDS to calculate with these results and even search by your own for a suitable method by opening the Drylab files (use Tom's spreadsheet to find a 2-step gradient, ...).
4) ease of use: it's very easy, step to step wizard, then start button and it will run. Precision: depends of the integration, which can be done manually afterwards, and the accuracy of the dwell volume, which should be measured before input. The precision depends for a great part of the precision of Drylab. For this you should went to mr Jupille, he can answer if he want :lol: .
Bart
I'm not interested in the AMD because of the first reason proposed by Tom i.e. "The system was never intended to be used directly with impurity samples; it was designed for major-component type assays (potency, content uniformity, dissolution, etc.). The only way to use AMDS to effectively develop impurity methods is to work with spiked samples." In general, I derive my potency and dissolution methods from my purity method. I generally use stressed samples for purity method development where I am concern about peaks less than 1%.
In fact it's possible to work with this small peaks, altough its not recommanded.
The only thing is that the predictions wont be as accurately as possible.
This is a Drylab thing I guess.
But if you don't use Drylab (or another simulation software) for method development, you will waste a lot of time.
Bart
Users browsing this forum: Semrush [Bot] and 11 guests
