varian 3800 overflow too high
Hi everyone,
New to this forum. I conditioned SPME fiber on standard conditions (1 hour) then changed method to run a blank but my instrument never got ready. message is always NOT READY. I looked up in to manual and one possibility they told "mismatch between the parameters can cause this kind of problem". While looking at the panel on instrument, I have noticed the column flow rate is more than 8 ml/min which should be around 1.
Any suggestions what problem it might be?
Thanks in advance
Kamran
Welcome to the forum.
Like most new members you overstimate our abilities to troubleshoot by guessing. To make sensible suggestions we need to know what your method and instrument conditions are - in detail.
Like most new members you overestimate our abilities to troubleshoot by guessing. To make sensible suggestions we need to know what your method and instrument conditions are - in detail.
