HPLC Column
is it possible to acetone for reverse phase HPLC?
Yes, basically it is possible to use acetone (and it actually has a quite high elution power, higher as acetonitrile) but the UV-cutoff is pretty high. I don't remember exactly but I think it's higher than 300 nm, so working in the usual UV range is rather impossible.
If you plan on using a UV-Vis/DAD for detection chances are you're out of luck. If you plan on using refractive index, it should work.
And if your sealings will withstand Acetone yes!
I quote Gerhard, check the compatibility of your seals and tubing
In total there are 17 users online :: 1 registered, 0 hidden and 16 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot] and 16 guests
