to make c-18 reverse phase column
hello everyone!
now i make c-18 reverse phase column myself,but the presuer was so high .i do'nt know why ! is here someone know some method to make c-18 reverse phase column!
thank you ,i apreciate your anwser!
What exactly do you mean ,are you using RP-C18 for your chromatographic analysis or you manufacture your own C-18 column?
Hi there,
If you want to pack your own HPLC columns ( stainless steel columns) you need special equipment which is probably not available in your lab I'm afraid.
You need a constant pressure pump ( up to 1000 bar) and filing vessel capapble of handling the high pressure.
If you want to pack minibore columns ( ID less 2mm) you could use a constant flow pump, any HPLC pump will do and try to fill these columns.
However it is a particular job and a lot of experience and proper proceuders have to be followed.
This knowledge is protected by column manufacturers.
Philippe
hello everyone!
How did you pack your column? Who suggested you instead of analysis manufacture column :D
Amaryl.
Users browsing this forum: Google [Bot], Semrush [Bot] and 10 guests
