empower3, generate postscript file
I'm new to empower3 and trying to figure out how to create a post script or adobe illustrator readable file for processing the figures to get high resolution images. Appreciate your help in advance.
Empower comes with an Amyuni PDF generator labeled as the "Waters PDF Generator".
In order for this driver to work on account of licensing restrictions between Waters and Amyuni, the PDF request must come from within Empower.
So ... create a report that shows what you want. Select your result file(s), right click and choose Preview/Publisher. Load the report that you want and click the disk icon to save. You will now have a PDF.
I believe that you are able to change the PDF dpi within the driver itself.
Is there any way I can generate an csv file or data file rather than pdf file
Yes, you can create export methods within Empower to export the data you want into a CSV.
From the Methods tab of the project, select File and New. Choose Export Method...
From there a window will open up and you can choose to export specific fields or raw data depending upon what you are after.
