DB-5MS column for halogenated disinfection byproducts
Hi Everyone,
I'm interested in analyzing some DBPs by GC-ECD (haloacetic acids, trihalomethanes). EPA methods and others recommend using a DB-1 column, 1.0 um thickness but I currently have a DB-5MS column, 0.25 um - all other characteristics equal.
Does anyone have experience using an alternative phase column for these types of compounds? Should I adjust the method to account for difference in phase thickness?
Thanks!
Hi Everyone,
Thanks!
IMHO you won't get sufficient resolution with 0.25 µm film thickness.
This really is is a case of "Don't think, try it" to slightly misquote former forum member Hans Muller.
To a first approximation your thinner film will shorten the retentions by a factor of 4 so you will probably have to lower the column temperature.
Please report your findings here.
