Ask help for seperation DOTA & DTPA related compounds!
I have some difficulties in seperation some compounds like DOTA & DTPA which contain 3-4 COOH groups and 4 tertiary-amine groups. Those compounds came out either at the dead time (reverse phase column) or disappeared (normal phase column). Is there anybody with any experience on such compounds? Thanks !
One way of dealing with this stuff is playing with buffers - if your column allows it - frpm pH 2 to pH 11, and see how your analytes reacts.
I assume you are doing RP at low pH, otherwise you should ge retention.
I'd say that your compound should be run under HILIC conditions.
Compounds that elute in the void on RP columns or require addition of IP-reagents are those best suited for HILIC. I would also bet that your compound have a very high interaction with the NP column you tested, which incidently would be the same if you tried a silica HILIC column.
There are though other HILIC phases available, check previous post @ this forum, and our zwitterionic phases might be one suitable alternative.
If you are not familiar with HILIC as technique, a copy of our "HILIC guide" can be ordered via our homepage.
Merck SeQuant AB
www.sequant.com
HILIC will definitely work. You may also want to try ion exchange.
Z.-X. JIANG,
We have a method for DOTA and related compounds on Primesep D column. It is not on the web yet but if you provide us with your email I will send you technical note on DOTA retention/separation.
Vlad
Users browsing this forum: John Guajardo and 14 guests
