column bleed
Hi, could someone please explain what is meant by 'column bleed' in GC.
Is it the wearing off of stationary phase in the column as the column ages?
Also would it be correct to say that there are normal (normal background signal by the stationary phase) and abnormal (a rise in baseline)?
thank you.
Hi
Basically, you are correct
Try looking at these articles
http://www.sge.com/support/training/col ... lumn-bleed
http://www.sigmaaldrich.com/technical-d ... s-low.html
Ralph
Ralph
GOM: Thank you for the links..
Would it also be correct to say that minors peaks (besides peaks of analytes of interest) on the baseline of the chromatogram represent noise?
Thank you.
Hi chemgc779
No, noise on the baseline signal is a bit like the background hiss on an audio signal.
Does that help?
I wonder if you would be better posting your queries on the Student section for better help from the forum
Kind regards
Ralph
Ralph
