degasser
hi everybody ,
as we knew that there is a degasser for the degassing of mobile phase in HPLC , i would like to know what is the input of a degasser and the mechanism of it.
regards,
sudhi
Most degasseurs uses vaccum along with micro-porous tubing...
The degasser passes the mobile phase through gas-permeable fluorocarbon tubing. The tubing is inside a vacuum chamber. The original designs (~1992) used macro-porous PTFE, and were susceptible to contamination, had a large internal volume (15 mL). With time, better tubing materials (Teflon AF) and vacuum control have reduced the volume (2mL) and resistance to contamination (no macro-pores). The exhaust from the vacuum contains the gasses removed from the mobile phase, plus whatever solvent can diffuse through the teflon.
Mark Tracy
Senior Chemist
Dionex Corp.
Users browsing this forum: Semrush [Bot] and 8 guests
