Setting up an ELSD detector
I am trying to set up an Agilent 1100 series to a PL 2100 ELSD for surfactant analysis.
I have the detector and HPLC but i am unsure of what other components will be needed to get the system up and running.
Any help would be greatly appreciated.
Hello
If you're going to use Chemstation/OpenLab as software you will need Agilent 35900E Dual Channel Interface to have signal from ELSD in Chemstation.
Tomasz Kubowicz
Hello
Tomasz Kubowicz
That's what we did with our ELSD and other external detectors.
This may be stating the obvious, but you need a gas (nitrogen) supply for the nebuliser.
