CP-3800 with ezchrom
We run CP-3800's using ezchrom and are trying to inject separate samples in each column. I cannot figure out how to set up ezchrom to do a separate sequence for each channel (like it does for Agilent's GCs) or to acquire two sequence entries at once (like chemstations "unlinked").
Has anyone had any success running two different samples at once on an CP-3800 using ezchrom? How do you do it?
Thank you,
Damien
Is your GC equipped with two injection towers? the Agilent GC's can be and then I can set the injection to Dual and have two samples being injected simultaneously.
Freek Varossieau
OpenLab CDS 2 specialist
BeyondOpenLab
beyondopenlab@gmail.com
+5977114721
