MSFault detected: 5.1 Firmware DSP error ?
Hi everyone,
I am using : 7890 A GC and 7000 Triple Quad MS
Recently that warning occur to my firmware.
And that situation stop the sequence and i can only done one injection each time. I have to load sequence back and back restart again to sequence.
Do you guys have any ide about the solve this problem? And why its happening?
Sounds like a communication sort of error. Restart soft-and hardware, check cables and if it persist i suggest you contact Agilent for this issue.
Thank you,i'll try it
Did you ever fix this problem?
I am getting this 5.1 firmware DSP error, as well on my 7000C. I get through 2 injections, then the sequence stops.
I just power cycled the whole system but I'm not convinced this will fix things.
Any tips would be greatly appreciated.
