Suplies for HP1050
Hello.
Anybody know where i can buy suplies for HPLC HP1050 in USA?
I'm looking for:
-Purge valve.
-Steel capillar 0,18 mm I.D.
Thank you very much.
Both the purge valve and capillaries should be available from Agilent or Restek, as used in later 1100 and 1200 models.
Restek handles most of the consumables. You don't have to use the 0.18 capillaries - you can just replace everything with PEEK.
Agilent still sells some of the non-consumable parts. If they don't have them you might try Alpha Omega. Or, you can do what most of us who are foolish enough to still run these do - buy used systems and scavenge them.
Mark Krause
Laboratory Director
Krause Analytical
Austin, TX USA
Users browsing this forum: Bing [Bot] and 22 guests
