HPLC Vitamin C
I am trying to to determine the concentration of vitamin C in some supplement samples. I was wondering if anyone can confirm if running gradient using mobile phase of A( 0.1% acetic acid in water) and B (methanol) with addition of 5 mM of hexane sulfonic acid sodium salt would work?
Thanks.
Hello.
We use an isocratic method at C18 with Tetrabutylammonium hydrogen sulfate as an ion-pairing agent.
Best regards,
Dmitriy A. Perlow
I used to use (~40 years ago) an isocratic method using a 250 mm C18 column and a mobile phase of Methanol/cold Metaphosphoric acid for Vitamin C in fish food.
Look at this. Perhaps it helps you.
Trends in Analytical Chemistry, Vol. 27, No. 10, 2008
Have you tried an HILIC method? Give it a shot.
Q. F. Ignacio Viera
For fish food I used a C18 column and a Mobile Phase (isocratic) of 90% cold metaphosphoric acid in ACN. Wavelength was 248 nm.
That was ~30 years ago (I think)!
In total there are 29 users online :: 1 registered, 0 hidden and 28 guests (based on users active over the past 5 minutes)
Users browsing this forum: Google [Bot] and 28 guests
