how to reach 100% total volume?
I worked on a gas chromatograph (Perkin Elmer Clarus 480) and the total result does not exceed 100% sometimes 37%-24%
https://imgur.com/a/QDnv1
and I do not know what it the problem?
There are many peaks that are totally retained by the GC column! As an example; if you take the column offline and make an injection it will not match the same injection made with the column online.
In total there are 27 users online :: 2 registered, 0 hidden and 25 guests (based on users active over the past 5 minutes)
Users browsing this forum: Ahrefs [Bot], Semrush [Bot] and 25 guests
