nitrogen generator
T :D hank you very much for your reply.
There is a new problem again.
the reading in the nitrogen generator panel reads "COMMS 1 fails".
The Generator is of Dominic Hunter make. It wa recently installed and only used for around 1000 hrs but is down . What do you think is the problem. Any body there is using a DOminic Hunter`s Nitrogen Genetor Please help. :(
If the hardware is recently installed you need to be phoning the local agents for support.
