Can you display CConst fields in a report?
I know that, in order to see a CConst value in peaks or review mode, you need to convert it to a Calculated Custom Field but is there a way to display the CConst in the "Components" tab of your proc method in a report, as in CConst1 and its contents etc?
Looking at the report editor, you can add proc methods but it only seems to show generic info like ID number etc, can it go further?
hi ,
good question
Yes you can display CConstx in processing report but I think that is about it , unless you go down the route of custom field
Could you use a peak column (units and edit mayb) and set this to equal Cconst ?
Thanks very much for the reply, I tested it and yes, the proc method can display in its entirety and it shows the CConst fields. Thanks for the tip.
In total there are 24 users online :: 2 registered, 0 hidden and 22 guests (based on users active over the past 5 minutes)
Users browsing this forum: Amazon [Bot], Majestic-12 [Bot] and 22 guests
