Determination EG by using GCMS
Does any one knows a method for " Determination of Ethylene Glycol in aqueous environmental sample using GC-MS"
I have found one method which require deriviatazaion. I want t directly inject into GC-MS
I have done it before direct inject but it isn't the best thing for the MS injecting water. I was using an old HP5995 which had solid metal quads.
For best separation you will want to use a Wax column, Restek makes a StabilWax-MS column that has very low bleed which should work.
Extracting it is nigh on impossible. We do what James does; direct injection onto a polar phase. Works for mono, di and tri ethylene glycols.
Mark Krause
Laboratory Director
Krause Analytical
Austin, TX USA
