hydrogen as carrier gas in GC-MS
9 posts Page 1 of 1
A thread on the GC forum has evloved into a discussion on whether hydrogen is suitable as a carrier gas when doing GC-MS. Problems of pumpability, reactivity and explosions have been aired.
What do the MS experts say ??
used it seveal times when we couldn't reproduce the retention times of complex mixtures and correlate to our GC labs results.
No problems that I remember, should use same caution that one would use for GC.
Good link at
http://www.chem.agilent.com/cag/servsup ... afety.html
Sailor
One important consideration in the use of hydrogen as a carrier gas in GC/MS is that hydrogen is not pumped as efficiently as helium by turbo molecular pumps. The difference is about 30% poorer performance with hydrogen than helium. There is no difference between the pumping of hydrogen and helium with an oil diffusion pump. The QIT GC/MS has the potential of being the instrument most effected by the use of hydrogen.
Regards;
David
O. David Sparkman
Consultant-At-Large
Application of hydrogen as gas - carrier in GC/MS results in strong change of mass - spectra terpenic alcohols. Usually it - reduction of intensity of an ion with mass 71. It occurs as a result of attack of a radical of hydrogen to OH-group and removal waters from a corresponding ion.
Boris Vinogradov (essential oil researcher)
Boris, are you concluding from the results that a hydrogen atom reacts directly with the OH group to remove H2O, or do you have independent evidence for that?
Boris,
On a separate issue, I am looking for someone to help me beta test a piece of software that I have been working on that identifies the amount and types of essential oils in a mixture of oils. I would need FID results from some mixed oil samples - would you be able to help?
Ralph
I did not carry out special researches. This my assumption.
Comparative mass - spectra terpenic alcohol (received in hydrogen and librarian) can be looked on viness.narod.ru/mass.htm
Boris,
Ralph
Why not. My e-mail vin-ess@mail.ru
Great - thanks
Ralph
9 posts Page 1 of 1
In total there are 33 users online :: 0 registered, 0 hidden and 33 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 33 guests
