isopropylic alcohol(API) separation column in Helium
I would like to know which column to use to separate isopropylic alcohol (API) from O2, CO, CO2, H2, N2 in background Helium using Helium carrier gas.
Thank you for your help
almost any column packed or capillary will work.
Porous polymer
Carbowax
any boiling point phase column
I would prefer a Supelcowax capillary.
If you are using a flame ionisation detector you do not need a column at all becuase it will not respond to any of the gases.
