Perkin Elmer Clarus - attenuation
We are performing a method transfer. The customer has in their method, which is run on a Perkin Elmer Clarus GC, attenuation -3(8). We have an Agilent 6890, but the attenuation can only be set to 0-10. Does anyone know if -3 on a P.E. Clarus is equivalent to 8 on an Agilent 6890? Thanks.
Unless you use the analog signal output on the 6890, the Range setting will not have any effect. It will just influence the signal level on the signal output to any A/D converter or chart recorder.
JW
Applied Instruments
hi
how are you ?
i want you help me i have problem with detecor ECD in GC perkin elmer clarus 500, i try to regulate the flow make -up manuellement but i can not;
i dont know the problem exectly , i no detect the gase in the oulet fo the detector ECD , no gas in outlet, i wait your message . and thanks so.
my msn is : hmida02ch@hotmail.com
la science c'est la vie , et la vie c'est notre science
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot] and 7 guests
