EPS (extra polar site) column conditions
hello to all,
Does any body knows the required conditions for the EPS column?
I am planning to use Platinum EPS C18 300A 5u from Alltech for my experiment (trying to study the cross links from collagen protein).
Is there any special procedures in terms of cleaning the column between
each experiment?
Is there any specific solvent, I should use for this kind of column ?
Thanks in advance for the answers.
In general, the "embedded polar" columns can be treated pretty much the same way as any silica-based reversed-phase column.
300A "protein" rp columns mobile phase is typically ACN/Water... some employ use of 0.1% TFA...
Buffer Removal - 5 to 10% Organic in Aqueous...
Organic Flush - 100% ACN....
Storage - anywhere from 65/35 - Organic/Water... make sure no buffer.....
Hope this helps....
Ktown213
Tom Jupille
and ktown213
Thanks for the answers.
Rajeev
In total there are 26 users online :: 1 registered, 0 hidden and 25 guests (based on users active over the past 5 minutes)
Users browsing this forum: Google [Bot] and 25 guests
