Determining void time for a Atlantis HILIC column
Hi all,
can anyone tell me the proper way to determine the void time on a HILIC column? I assume sodium nitrate would not be the ideal compound to determine this value on a HILIC column.
The easiest way would be to simply inject a blank of ACN/water at a different ratio from your mobile phase, set your detector out at fairly long wavelength and high sensitivity and look for the refractive index shift.
That would work, though I might do it a bit differently.
I would think that a mobile phase containing anything from 50-95% ACN and a dilute solution of something like toluene in ACN (maybe 200 ppm?) would do nicely enough.
Toluene is what we use for determining the void volume on our Zwitterionic HILIC phases. It works!
Merck SeQuant AB
www.sequant.com
