further questions on buffer and modifiers
Sometimes people buffer pH with buffers, sometimes people simply add acid or base in mobile phase, based on what should I choose?
You need at least 1 millimolar capacity in order to have a stable pH, reasonable equilibration times, reproducible preparation, and resistance to sample effects.
Therefore, if you need a pH between 3 and 11, use a real buffer. For pH <2 a dilute acid is OK; for pH > 12 dilute base is OK. For pH 2-3 or 11-12 you can do it either way.
Mark Tracy
Senior Chemist
Dionex Corp.
Senior Chemist
Dionex Corp.
thanks
In total there are 17 users online :: 1 registered, 0 hidden and 16 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot] and 16 guests
