export chromatogram with empower2 software (waters) as ascii
I would like to ask if someone of you uses
the Empower 2 Software (Waters) for data processing
and could tell me how to export an
hplc- chromatogram (and if possible some online- spectra)
in ascii- format?
I am not able to create an satisfying export method...
thanks in advance!!!
As far as I can remember, you simply use the defalut parameters of the export method. However, I am pretty sure this only works on single channel data or an extracted 2D channel. I dont belive you can export out UV spectra.
May I ask why you wish to do this?
You can export your raw data as an ASCII file, which you can read in excel, .....
When you make a new export method, go to the tab "raw data", an set ASCII, file. Choose a path, save your method, and things should work.
Bart
