Valproic acid: peak tailing problem
Dear friends,
Am doing the method development of Valproic acid. IK have problems with the base line (very high ) and the peak shape is bad with severe tailing. I have used almost all cominations olf LCMS buffers as Mp and tried with different columns. The method is a SIM.
If anyone has any idea about the method, please help me
shan
hi
i would ask u first the basic question about valproic acid. it is not fragmenting in LCMSMS. so can u please tell me which ion you have selected?? As we have done valproic acid as PsedoSRM method in LCMSMS.
ADPATEL
One of our customers had same problem with tailing of valproic acid on a regular C18 column. We developed the following method for LC/MS:
http://www.sielc.com/compound_207.html
regards,
Vlad
dear aplesh
Even am using a pseudo SRM for the amu 142.9. Could you please get me some literature which is helpful.
First: What ESI mode are you using? As VA is an acid, you should use Negative Mode...
