PAH analysis
Hi
Is there a method for PAH analysis using GC with an FID detector?
Any information pertaining on this subject would be most helpful.
Noodles
There are so many references for this they are innumerable.
Google will overwhelm you with references.
Take your pick.
Look at any of the many column manufacturers and you will see standards and sample chromatograms displayed.
Take your pick.
Noodles,
Rod is right, lots of references. Here is a starting point.
http://www.accustandard.com/asi/pdfs/ep ... s/8100.pdf
Best regards.
