2-Fluoro Toluene GC analysis for isomers
Dear All,
I am trying to separate 2-Fluorotoluene from its isomers 3-Fluoro and 4-Fluorotoluenes by GC. But I am unable to get good separation even with 75metres column also(I used AT-Wax).I hardly getting a resolution of 1. But I am unable to get Base to base separation.
Can any body have any experience with these isomers.And can you please share the GC method.
Thanks in advance
difficult separation, yes. But I don't have a solution for you.
Things to try:
Determine if you are running at optimum flow and temperature parameters, lower flow and temperature parameters even lower, just to make sure.
a trifluoropropyl methyl capillary?
a chiral GC column?
a bentone 34 capillary column
gas solid chromatography mechanism
Call a supplier of the isomers and ask them what they use.
Try LC or NMR to achieve purity determination.
Take a vacation and think about it for while.
Good luck and best wishes,
Chromatographer1
Users browsing this forum: Semrush [Bot] and 8 guests
