how we can prepare holium perchlorate solution
8 posts Page 1 of 1
regarding:
whether its has any affect to sunlight...
[/img]
Y.K.K.Reddy
but while am preparing the solution it was changing its color.... is there any intetrference with light?
quote="JGK"]Some info here:
http://www.starna.co.uk/ukhome/faqdatasheet/MSDS-HL.HTM[/quote]
Y.K.K.Reddy
why not do a small experiment, prepare it in the dark at room temp, see if the color change is still evident, maybe even try in the dark at a lower temp (say 4C) to check for temperature effects.
sounds like fun! if you do this, please report your observations back here
peggsy
sir
i did that experiment in a closed room ther it doesnt change its colour when i went outside its changes its color.. wat the reason for changing the color
Y.K.K.Reddy
how did you prepare your solution, what grade are the reagents that were used?
This solution would seem to be quite stable from what i can find on the web (google and lit searches). I am unfamiliar with this solution, what is the exact color change that occurs? Nice challenge indeed.
the color is pale white in color first and changes to slight pink based on the light ....
Y.K.K.Reddy
how did you prepare your solution, what grade are the reagents (solvents included) that were used?
8 posts Page 1 of 1
