Dummy data in Empower
Hi there,
Is there any way to generate some kind of dummy data in empower??
Let's assume that I need to test and validate a custom field but I don't have a sample set because there was no time for doing the analysis, so I need some kind of "dummy" sample set to test.
The other way is to have some kind of "dummy" hplc, is there something like this, some kind of a software or something?
I think Empower has a built in default project with a variety of standard and sample injections for testing custom fields, processing etc try there.
Or copy some data from another project to the new one and test with that (e.g. select a run SampleSet, right click, copy to project)
Don't know if it will work if your custom field is of "Sample" or "SampleSet"-type and it wasn't there when creating the SampleSet? Maybe you can create a new "ProcessOnly"-sample set.
