Peak purity analyte peak in Assay or RS by Gas chromatograph
I want to know how we can conclude that a peak of GC chromatogram is pure (contains only one substance)? What is the simply way to check / test the peak purity?
Other than using a mass spectrometer, (and even that is not 100%) another way is to use two dimensional chromatography using two columns with two vastly different selectivities with heartcut or other means to isolate a peak. That too may not be 100% certain.
You can approach 100% certainty with many analytes, but as a GENERAL question, there is no absolute way you can prove any peak is singular in composition.
In total there are 20 users online :: 1 registered, 0 hidden and 19 guests (based on users active over the past 5 minutes)
Users browsing this forum: Ahrefs [Bot] and 19 guests
