UPLC vs Aglent 1200 rapid resolution
Please give me your experiances with this systems,especially in aspect transferring method from one to another.How much are they compatible .
Thanks in advance
These are two different systems from different manufacturers, with different designs and software.
You should expect differences whenever you switch methods to a different instrument. If you have a simple isocratic method, the transfer may be easy. If you have a gradient method, some adjustment of operating conditions will probably be required.
Merlin K. L. Bicking, Ph.D.
ACCTA, Inc.
Thank you
