amines
9 posts Page 1 of 1
I´ve to test a method for MDEA, i need to know if the column i have can be used with water as solvent.
Column: WCOT FUSED SILICA 30MX0.25MM ID COATING CP-SIL 8CB DF=0.5 FOR AMINES. VARIAN CP7595
Do you know any method for MDEA by GC-FID?
Thanks.
Maybe. But it "might" help if you specify what "MDEA" is. I know that "DEA" is Drug Enforcement Administration or could mean diethanolamine or diethylamine....
its methyl diethanol amine
This has appeared before. Have a look here.
viewtopic.php?t=24465
ohh thank you.
Could you tell me if the column i have can be inyected with water?
Do you know any method of MDEA in air or emission?
Did you try something like this?
http://www.restek.com/chromatogram/view/GC_CH00296
Yes it is a regulated pollutant by the EPA (see attached). No I have not found the limit in air.
https://iaspub.epa.gov/sor_internet/reg ... ceId=47573#
thank you..
Do you have any method of extraction for amines in air, water or soil and detection by GC-FID? i´m a little bit lost with this analyte...
9 posts Page 1 of 1
Users browsing this forum: Semrush [Bot] and 10 guests
