Empower processing - Bracket stds
Hi ,
I'm I missing something
When I review results using a processing method where sample set was set up with bracket standards the results are quantified by total standard (calibration curve all points)
It is not until results are processed and result set is created that bracketing standards are used with labels
how do you review and check results before processing if bracketing stds ?
Much appreciated
Hello
Is the bracketing standard used for quantification?
Thanks and Regards
Rathan
Yes ,
bracket stds used to quantify
You don't (via Empower).
If you're *really* chomping at the bit, export the peak areas and do it in Excel. Otherwise, wait and process in Empower.
