ZIC-HILIC Column cleaning
Hello experts,
I am using a ZIC-HILIC column to detect polar molecules, but I have some background peaks. Could I clean it eluting only water+2% ACN for a while or the column would be damaged?
Thanks you for your help!
Afaik 100 % water may be fine too, check for column regeneration: http://ftp.mn-net.com/english/Instructi ... 905_EN.pdf.
Best regards,
Dmitriy A. Perlow
Good morning,
I agree with DAP. Here's another link to follow:
https://www.nestgrp.com/pdf/Zp1/zh.colcare/zicopm.pdf
MattM
Thank you very much!!
