MassHunter: decimal places and chromatogram areas
hi to all,
i'm wandering if it's possible to set the number of decimal places in area values of integrated peaks in TIC chromatograms. often, it happens that when I integrate manually peaks in chromatograms, the value of area has not decimal places.
thanks
There is a xml file in c:\users\(user name)\AppData\roaming\Agilent_Technologies\ (the file is appsettings.xml or something similar). With notepad you can open this file and change number of digits after decimal point, but please do a backup of this file
Thank you very much for answering to my question. unfortunatelly, i can't find this file. probably, the path is not proper to my pc.
