pka table values
Hi people! can anyone tell me if there exists on the net some table values´s page in order to find quickly the pka of any substance? i´m talking about common pharmaceutical drugs, vitamins, etc...
Thanks!!!!! :D
I personally use "CRC Handbook of Chemistry and Physics" and "Lange's Handbook of Chemstry" togehther with a few others but if you like online, here is a pdf document:
http://research.chem.psu.edu/brpgroup/p ... lation.pdf
and then there is that one:
http://www.chemicalforums.com/index.php?page=pkavalues
You might find more if you search for them.
Robert Haefele
thank you so much robert. I appreciate your help!
:D
Another link worth mentioning:
http://www.chem.wisc.edu/areas/reich/pkatable/
thank you so much!!!!, an excellent link!!!
Hello all,
it may be a little too late but her are two other links:
- first drugbank were most of the commercial drugs are cited with phys-chem properties : http://www.drugbank.ca/
-second, an online software that calculate pKa from chemical structure, i found good correlation with litterature values : http://www.vcclab.org/lab/alogps/
Hope it is helpful
cheers
"AD VERITATEM PER SCIENTIAM"
Users browsing this forum: Semrush [Bot] and 22 guests
