The problem with the solenoid valve
Hi
I use DANi master GC-FID.
I have problem with solenoid valve (brand: SIRAI V366B01BL). I hear leaking at the solenoid valve, when i inject sample to the GC after a few minute air leak will stop and we hear no sounds but after finish the run time leak start again. now i dont know how to fix it?
I assume that you tried tightening the fittings for the tubing that goes into the valve. If not, do that first. If that doesn't fix the problem, you can always buy a new valve.
Are you injecting splittless and going to split at some time? Or is this a valve injection?
Best regards,
AICMM
