Make up gas for NPD (FTD) detector
Hi all,
As I've known, NPD detector can operate with nitrogen as make up gas. But I just learn that the Shimadzu 2010 GC NPD (FTD) uses only Helium as make up gas. I am puzzled why's that.
Can I use nitrogen instead ?
You can use nitrogen as make up but helium is preferred. You must bear in mind that the amount of hydrogen relative to the other gases will affect
nitrogen-to-carbon selectivity of the detector so helium is usually the gas mainly used.
