I have a question and would like some advice.
I am experiencing retention time shifts for my compound peaks on my Agilent 1200 HPLC coupled to a MS system and I would like to ask if there is anything that I need to check:
i) Already re-prepare fresh batch of HPLC gradient - no avail
ii) Check the pump flow rate - suspecting there might be problem with the pump - however, flow rate of pump is ok
iii) Check on HPLC column, change to other column - also didnt solve the time shifts
iv) Running back the same samples that have been ran previously confirms the shifts
v) Will try to check and change the guard column cartridge , hopefully, this will help.
However, is there any other advice that can be given to me? I thought of checking the mixer; not sure this will works or not.
Please advise me and thanks a lot !!!
